Clicking spot does not change radio frequency and mode
Please read here before asking
As detailed in the user guide clicking cluster spots work as follows ..
Cluster actions
Single click on cluster spot
1. Adds call to call sign input field
2. Looks call sign up in Clublog Exceptions file, QRZ, Recent calls and completed data fields
3. Checks for SOTA or IOTA or other award reference in comments and notes fields and completes the appropriate awards program fields.
4. Fills country worked by mode and band graph
5. Draws great circle path on world map
6. Opens the large-scale station location map and biography photo if available from lookup site
7. Fills SP/LP headings, antenna elevation and distances in the Contact(F3) tab
8. Adds data to the Info (F1) tab for the station
9. Displays 'Worked' banner in the lookup data box - If 'Worked before' is clicked the worked before window opens displaying all previous contacts with that station.
10. If a call sign is found for call during lookup, clicking the lookup providers name (QRZ, HamQTH) opens the web browser at the page of the call sign
11. Fills mode, frequency and band in the input window if CAT is enabled.
Double click on cluster spot
All as above (Items 1 - 11) plus changes radio mode and frequency on the radio.
