UTC Clock in window title?
ng7v
Post by ng7v »
Would it be possible to put the UTC time in the main window title in bold letters?
Ron (NG7V)
ei6kw
Re: UTC Clock in window title?
Post by ei6kw »
Clock from Utilities -> UTC Clock is not enough?
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
Below is an image of my desktop with the UTC Clock that Slav noted in his post above.
Would that not work for you?
ng7v
Post by ng7v »
Yes I found that clock and to me it is just one more window to manage. If a simple clock in the window title (next to the version number which isn't very useful because it is available in the about menu item) would work very well for everyone. Nothing fancy, just the current UTC time would be just right.
Ron (NG7V)
ng7v wrote: 11 Jul 2022, 00:56 the version number which isn't very useful because it is available in the about menu item
In your opinion! but you would be surprised how usefull it is to the team when testing several Alpha releases a day or troubleshooting for a user that cant find his butt with both hands.
Of course the GMT/UTC clock is already immediately visible to the right of the call sign/Contact name field in the input pane! However your request is noted.
ng7v
Post by ng7v »
I knew you would respond to it. Good point and thank you for pointing out the qso start/end time. I can't say I noticed it before but then I'm just one of those know it all guys. I withdraw my suggestion with all due deference.
Ron (NG7V)
