Setup of your own award
Moderator: OE6CLD
on6at
Post by on6at »
I made a few custom award setups.
Some of those award or callsigns are connected with points.
Like AMRS (Austrain Military Radio Society), there are several stations to work and some stations are good for 2 points, others for 3 or 1 point and 1 station for 10 points.
I was wondering what setting I should use to make those points visible in statistics.
Now I only see the number of different calls I've worked on.
See below:
awards with points.jpg (104.62 KiB) Viewed 7225 times
There are still awards that work with points.
Version 2.23.0.0 - Windows 11
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
OE6CLD
Re: Setup of your own award
Post by OE6CLD »
Hi Patrick,
At the moment there is no way to track awards with callsigns worth different points. Therefore it would be necessary to have an internal list with all valid callsigns and their point value. This it not possible in Log4OM for now. I track these awards by adding the points into the comment field.
Claus, OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
on6at
Post by on6at »
Hi Claus,
Sorry for the late reply, but just saw your reply. I was unable to be active much due to illness.
Can you give an example of how you mention those points in the comment field?
Is that the form: IPA;1p for example?
Or maybe something else?
73 Patrick ON6AT
Member UBA-IPA
WCA: ON-01354
