VFO Offset
G4KCM
VFO Offset
Post by G4KCM »
I just wondered if there was a fix in the pipeline to allow a negative VFO offset to work.
Using the little gear wheel icon adjacent the frequency display on Log4OM a positive VFO offset works fine but if a negative value is entered the offset is not applied. I mentioned it a couple of years ago as I see have some others.
As always thank you so much for the hard work on Log4OM.
Best 73
Clive, G4KCM
Re: VFO Offset
Being fixed as I write so should be OK for next Beta release
G4KCM
Re: VFO Offset
Post by G4KCM »
Thanks Terry, much appreciated!
I think that will make quite few people who use QO-100 and SDR Console happy. Donation on it's way.
Clive, G4KCM
