Keyer with FTdx101D
F6FLU
Keyer with FTdx101D
Post by F6FLU »
Does anyone use Log'OM's CW Keyer with the FT101d?
here it tells me :
"A device attached to the system is not working properly".
That said, I'm not sure the FTdx101 uses a K1EL Keyer?
Do you have any info on this subject?
Pb Keyer FT101.jpg (244.14 KiB) Viewed 1268 times
Dan - F6FLU
https://F6FLU.org
Re: Keyer with FTdx101D
For the Log4OM keyer to work you either need to have a K1EL Winkeyer interface for normal physical radios or if using an Expert Electronics SunSDR use the special TCI interface.
The Winkeyer interface also functions with Flexradio 6000 series SDR radios without a Winkeyer interface due to their built in Winkeyer emulation in software.
Mainline hardware radios radios from Icom, Yaesu and Kenwood do not have a built in Winkeyer, they do have an electronic keyer but at this time Log4OM does not support com port keying so they wont function.
F6FLU
Post by F6FLU »
Ok Terry it's clear
a hope to see Log4OM using the internal keyer of Yaesu and others?
Dan - F6FLU
https://F6FLU.org
Since i am a ham i use CW at the manual way. That means i´m using my fingers and my brain. Winkey makes contesting
easier but for all other kinds of CW keying the best way is the manual one ....
F6FLU
Post by F6FLU »
Yes thank you Juergen, but that's not my question,
you do as you want but your answer has nothing to do with my question and is therefore of no use ...
Dan - F6FLU
https://F6FLU.org
F6FLU wrote: 06 Aug 2022, 16:20 Ok Terry it's clear
FWIW adding the com port keyer is high on our list but i cant give you a time frame yet.
F6FLU
Post by F6FLU »
OK Terry
Dan - F6FLU
https://F6FLU.org
