Has it ever been considered in Log4OM, a window with grid squares, overlaid on a map...much like what you see on DxMaps ?
This would be great during contests, especially if worked grids could turn from colored(needed) to greyed out as they are worked.
N3FJP has a window that shows needed grids (green) and grids worked turn Red but it is very clunky and time consuming.
If you ever do consider adding this feature, please make such a window detachable from the main
program. Many use multiple monitors and it would be great to have just a Grids map one could be drag to a separate, large monitor.
...and then having the grids "grey out" as they are worked. Really would help visualize
which grids are still needed in VHF contests . Yes, i know GridTracker can do it but would be great if it was all integrated into one monolithic application.
Thanks so much for putting such a fine logger out there .
Grid Square's needed/worked Map overlay, window
Re: Grid Square's needed/worked Map overlay, window
Have you tried using DXAtlas in conjunction with Log4OM?
