Callsign lookup not working
I am running Log4omV2 with Gridtracker and WSJTX, everything seems to be running fine except the callsign lookup, entering any callsign inc mine does not produce the map, populate any OP fields and QRZ images etc. Its almost like its not connecting to QRZ or Hamqth, am I missing something? cheers Paul
Re: Callsign lookup not working
Try without grid tracker or what running by manual input of call direct into log4om
Hi Terry, it's the same standalone as with GT running, everything seems to run OK, logbook updates from GT, just manually entering a call doesn't pick up anything from QRZ, GT collects images & OP details from QRZ, it's the only thing that doesn't work....cheers Paul
Post a screenshot of the info providers window of the configuration after the set up test for qrz please
Hopefully its attached....
What version number of Log4OM are you using? Help/about
Are you on Skype? or do you have Teamviewer?
I'm using v2.23.0.0 I have team Viewer installed
Contact me on Skype Genes1 to set up a TeamViewer sked please
Can't find you on Skype so I've sent an email from QRZ
Cheers
Cheers
All sorted now, many thanks for the help Terry.....73 all
