Somewhere, once upon a time, I setup the bands I was interested in monitoring on the Cluster (f8) tab. I can not find where that is setup. I've lost my 6m antenna and no long am interested in those spots.
How can I edit that list (The "Band filter" list on Cluster (F8) under Filters)?
Version 2.23.0.0
User guide: Updated: 04/04/2022
Thanks,
Mike / KA4CDN
Cluster "Band filter" add/remove bands
Re: Cluster "Band filter" add/remove bands
Mike,
Go to: Settings / Program Configuration / User preferences
Select preferred bands/modes on that screen and be sure to tap the 'Save config' and/or 'Save and apply' buttons.
Also ... the current user guide is dated: 17/07/2022 5:28PM
Just a bit more current than the one you noted.
Thank you Nolan.
Found it but it was under User Configuration not Program Settings. I could find it w/o your help.
I did a Force Update on the manual and didn't get the latest. I'll have to go looking for it.
Thank you again for the fast response.
Mike
Mike
