Maly Vysotsky Island - no IOTA
OE6CLD
Post by OE6CLD »
I have many valid contacts with Maly Vysotsky Island in my OE6CLD log. During import these were changed to European Russia ( I had update countries in ADIF enabled). After changing these contacts back to Maly Vysotsky Is. (deleted), I am not able to select the IOTA group EU-117 anymore. Apparently this only is possible when the country is European Russia.
Claus, EI7JZ/OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
Re: Maly Vysotsky Island - no IOTA
Hi Claus,
IOTA references can be downloaded directly from RSGB website by Log4OM
DXCC and references are set in the file itself, so only valid islands for the DXCC set are shown.
It seems that RSGB consider the Island under European Russia, and this prevents the user interface to shown the reference elsewhere.
You can manually set it in QSO manual edit mode
