Log4om 2.23
omnirig cat control
Input or click on cluster a callsign to get infos or see if already worked than leave it and change the tuning of the radio (up or down the band).
This changes the inputted call sign to a different call , always the same for the current logsession.
Quite annoying and I did not note on previous releases.
73 de I0MOM Marco
Change of station logged callsign as radio tuning change
73 de I0MOM Marco
Re: Change of station logged callsign as radio tuning change
Solved !!
After noticing that the "abusive" callsign was the las one automatically logged from WSJT-X, I reinstalled WSJT-X and that solved !
Thanks for watching,
73 de I0MOM Marco
I
73 de I0MOM Marco
I
73 de I0MOM Marco
Marco,
Had you provided the full information like you were simultaneously using WSJT then I would have immediately pointed you in the correct direction and Lele and I would not have spent time puzzling what the problem was!
Message to everyone
Pleas provide FULL information when posting your problems including version numbers, other software integrated with Log4OM etc
Message to everyone
