Hello all,
I uploaded the Ver 2.24.0 of Log4om2 but I noticed that on the right of the main window the image available from the QRZ.com search source is small or does not appear or is incorrect. This malfunction was not detected in the previous ver 2.23.
I ask you if you need to perform new settings or there are other reasons.
Thank you in advance for your reply.
de Vincenzo i8bvw
Ver.2.24.00 image on main window
- Immagine1.png (10.36 KiB) Viewed 753 times
Re: Ver.2.24.00 image on main window
All ok Terry,
the problem is solved !!!!!
'73 de Vincenzo
'73 de Vincenzo
And ... your solution was what?
It may be helpful to other OMs who might experience similar.
