Solar flux A and K index values are zero
vk2qv
Post by vk2qv »
Hi
Recently I noticed in main window top right hand corner K and A index values are always zero.
I remember it very well it had data in the past.
The version i have is v.2.23.0.0.
Just wondering if anyone else had the same problem and how did you fix it?
73 Ras VK2QV
Re: Solar flux A and K index values are zero
If you search this forum you will see other posts about this and the response that it is fixed in the beta release, we posted today
LA6RJA
Post by LA6RJA »
Link has been repaired ...
vk2qv
Post by vk2qv »
G4POP wrote: 25 Nov 2022, 13:35 If you search this forum you will see other posts about this and the response that it is fixed in the beta release, we posted today
Thanks all. Beta version fixed the issue. 73 Ras
ve3wej
Post by ve3wej »
I downloaded and installed 2.24.0.5 with success. the fix is good, but just to let you know. it came up letting me know that 2.24.0.0 is available. stepping backwards???
log4om error.png (8.96 KiB) Viewed 1476 times
Dave ve3wej / ve3ie
If using beta releases torn of ew release notifications in config
