Solar flux A and K index values are zero
Posted: 25 Nov 2022, 11:59
by vk2qv
Hi
Recently I noticed in main window top right hand corner K and A index values are always zero.
I remember it very well it had data in the past.
The version i have is v.2.23.0.0.
Just wondering if anyone else had the same problem and how did you fix it?
73 Ras VK2QV
Re: Solar flux A and K index values are zero
Posted: 25 Nov 2022, 13:35
If you search this forum you will see other posts about this and the response that it is fixed in the beta release, we posted today
Posted: 25 Nov 2022, 16:21
by LA6RJA
https://www.log4om.com/l4ong/release/be ... 24_0_5.zip
Oops! That page can’t be found.
Posted: 25 Nov 2022, 21:07
by KI5IO
Link has been repaired ...
Posted: 26 Nov 2022, 04:24
by vk2qv
G4POP wrote: 25 Nov 2022, 13:35 If you search this forum you will see other posts about this and the response that it is fixed in the beta release, we posted today
Thanks all. Beta version fixed the issue. 73 Ras
Posted: 28 Nov 2022, 00:36
by ve3wej
I downloaded and installed 2.24.0.5 with success. the fix is good, but just to let you know. it came up letting me know that 2.24.0.0 is available. stepping backwards???
log4om error.png (8.96 KiB) Viewed 1481 times
Posted: 28 Nov 2022, 08:48
If using beta releases torn of ew release notifications in config
