Data lookup not working on entry
K2GRG
Post by K2GRG »
If I enter a callsign by typing it in the box, the data lookup function doesn't happen. If I click on a callsign that's in a cluster spot, it fills in the box, the small "data lookup" popup happens, and the data is filled and worked before data is shown. If I type it in myself, it doesn't lookup the data.
It's worked in the past, wonder what I did. Wonder if it's just me getting old.....
Green checkmarks on paid qrz and hamqth
Thanks very much
Windows OS: 10
Processor and ram type i7 with lots of ram
Log4OM release number 2.23.0.0
Release numbers of associated software
Radio make and model ft101d
CAT Interface usb
Cat control type (Hamlib or Omnirig) omnirig
Screenshot 2022-11-27 095444.png (33.92 KiB) Viewed 598 times
Re: Data lookup not working on entry
Greg,
Update to the most recent release and give it a try again.
Current release is: V 2.24.0.5
https://www.log4om.com/download/
K2GRG
Post by K2GRG »
That did it. Thanks very much, though I should have checked myself... Donation made to support Log4OM.
K2GRG wrote: 27 Nov 2022, 19:54 That did it. Thanks very much, though I should have checked myself... Donation made to support Log4OM.
Very good. Make sure you have the 'check for updates' tix boxes enabled to you get an alert on your Main UI when a newer version is made available.
