Hello All
Is there a help file showing how to use the internal spot server? I would like to use this feature but cannot find anything in the cluster help file or here on the forum as to how this is set up
Cheers
Paul - vk4ma
Internal spot server
Re: Internal spot server
Just set the cluster server to start automatically in the config then when you restart Log4OM the cluster spots will be sent on localhost port 23vk4ma wrote: 29 Dec 2022, 06:03 Hello All
Cheers
Paul - vk4ma
Depends how you want to use the data? in some applications its even simpler to display Log4OM cluster spots
