WSJT-X to Log4OM v2 not working
Posted: 09 Jan 2023, 10:20
by g3ziy
When I complete an FT8 QSO in WSJT-X and log the contact, I get this dialogue panel pop up:
JTalert error dialogue.png (195.39 KiB) Viewed 2421 times
So I tried importing the wsjtx_log.adi file, but got an error message from Log4OM v2 that it was invalid. I think maybe the two things are related.
Has anyone any idea how stop the error message from JTAlert, and import the adi file?
Re: WSJT-X to Log4OM v2 not working
Posted: 09 Jan 2023, 12:01
1. The message may not mean the QSO was not logged - check Log4OM and see if the QSO is there
2. There is a setting in WSJT where you can change the interval at which that message apears, try setting it for a longer time
Posted: 14 Jan 2023, 16:42
by N6VH
G4POP wrote: 09 Jan 2023, 12:01 1. The message may not mean the QSO was not logged - check Log4OM and see if the QSO is there
The interval change setting is in JTAlert, not WSJT-X.
Jim N6VH
Posted: 19 Jan 2023, 14:22
by G8AJM
I have a similar problem; I get the same error message but the QSO is not logged. The WSJT log file however imports fine manually.
Versions are:
JTAlert 2.60.2
Log4OM V2 v2.25.0.0
WSJT-X V2.5.4
Grateful for any thoughts/recommendations
73 Chris G8AJM
Posted: 19 Jan 2023, 14:42
Where are your sqlite files stored, directory path etc?
Was it working before?
Posted: 19 Jan 2023, 16:06
by G8AJM
Hi Terry
Files are in a folder on dropbox with a local synced copy on C drive. In the past that has worked well with Ver.1 and I think (but not sure) it worked when I first installed Ver 2 about a year ago. I have it this way so I can use desk pc or laptop to access the db. Everything works fine for normal logging direct to Log4OM (CW), it's just the JTAlert connection that isn't happy.
73 Chris G8AJM
Posted: 19 Jan 2023, 17:14
Jtalert or WSJ?
Did the FT8! Software work before or is this an initial set up of FT8 software?
Dropbox is fine that's what I use
Posted: 19 Jan 2023, 17:56
by G8AJM
Yes it has always worked ok. Have just noticed there is a new release so uninstalled old one and installed v2.6.1
It has carried on adding to the old wsjt adif file so I can still add to Log4OM manually but same problem; getting the same error message.
C.
Posted: 19 Jan 2023, 18:41
Contact me by email and we will have a chat on Skype
Email is on QRZ
