Would like to be able to turn off the Unique Key column...don't see it in Edit Table Layout.
Never use it.
Unique Key
Re: Unique Key
are you running in debug/trace mode? this column is visible only when debug is active
If you still have problems i suggest you to delete the relative layout configuration file from /user folder
Re: Unique Key
Yes...that was it...I had TRACE as the default logging level since I tend to keep that running to trap any problems.
Re: Unique Key
Good
in debug and trace we show the unique id of each QSO to help pinpointing specific situations on DB, but keeping debug/trace mode actives has a "relatively high" impact on data logged and this can result in a small slowdown of the entire system due to heavy traffic on disc
