DAV - Diploma degli Ambienti Vulcanici
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the DAV - Diploma degli Ambienti Vulcanici award. Copy the attached xml file (it should be named award_DAV.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
More information regarding the award can be found here: http://www.enzolog.org/arasitalia/DAV/
Claus, EI7JZ/OE6CLD
award_DAV.xml
DAV - Diploma degli Ambienti Vulvanici
(348.99 KiB) Downloaded 623 times
DAV Award.jpg (55.67 KiB) Viewed 4485 times
Claus, OE6CLD/DJ0DX/EI7JZ
