import problem
F6FLU
import problem
Post by F6FLU »
I want to import my QSOs made at the "Coupe du REF" contest this weekend
I ask Log4OM not to make corrections (Skip quality check corrections" and despite this choice Log4OM modifies the State field for me as you can see in the result file
There is no way to tell Log4OM to import without modifying anything because it's really annoying...
[IMPORT ADIF FORM] Begin ADIF import task
WARNING: Callsign: F5VV Date: 29/01/2023 15:40:18 Band: 20m Mode: CW QSO STATE CHANGED FROM 01 TO
WARNING: Callsign: F5VV Date: 29/01/2023 09:01:29 Band: 40m Mode: CW QSO STATE CHANGED FROM 01 TO
WARNING: Callsign: F5POJ Date: 29/01/2023 13:17:23 Band: 20m Mode: CW QSO STATE CHANGED FROM 02 TO
WARNING: Callsign: F5POJ Date: 28/01/2023 15:57:58 Band: 15m Mode: CW QSO STATE CHANGED FROM 02 TO
WARNING: Callsign: F5POJ Date: 29/01/2023 08:22:55 Band: 40m Mode: CW QSO STATE CHANGED FROM 02 TO
WARNING: Callsign: TM4K Date: 29/01/2023 08:48:04 Band: 10m Mode: CW QSO STATE CHANGED FROM 03 TO
WARNING: Callsign: TM4K Date: 28/01/2023 16:19:07 Band: 40m Mode: CW QSO STATE CHANGED FROM 03 TO
WARNING: Callsign: TM4K Date: 28/01/2023 10:18:48 Band: 15m Mode: CW QSO STATE CHANGED FROM 03 TO
WARNING: Callsign: TM4S Date: 29/01/2023 10:02:27 Band: 20m Mode: CW QSO STATE CHANGED FROM 04 TO
WARNING: Callsign: TM4S Date: 29/01/2023 08:26:17 Band: 40m Mode: CW QSO STATE CHANGED FROM 04 TO
WARNING: Callsign: F5IQJ Date: 29/01/2023 10:08:57 Band: 20m Mode: CW QSO STATE CHANGED FROM 05 TO
WARNING: Callsign: F6FMX Date: 29/01/2023 09:57:48 Band: 20m Mode: CW QSO STATE CHANGED FROM 07 TO
WARNING: Callsign: F6FMX Date: 29/01/2023 16:51:46 Band: 40m Mode: CW QSO STATE CHANGED FROM 07 TO
WARNING: Callsign: F5MPN Date: 28/01/2023 17:00:15 Band: 40m Mode: CW QSO STATE CHANGED FROM 08 TO
WARNING: Callsign: F6DEV Date: 29/01/2023 15:59:56 Band: 40m Mode: CW QSO STATE CHANGED FROM 09 TO
WARNING: Callsign: F6DEV Date: 28/01/2023 16:17:18 Band: 20m Mode: CW QSO STATE CHANGED FROM 09 TO
WARNING: Callsign: F6DEV Date: 29/01/2023 13:49:59 Band: 15m Mode: CW QSO STATE CHANGED FROM 09 TO
SEARCHING FULL AWARDS REFERENCES...
End of ADIF import
Begin LOG save
LOG saved
Save completed
Dan - F6FLU
https://F6FLU.org
Re: import problem
Please update to 2.26.0.3 Beta as we made some changes to import routines
F6FLU
Re: import problem
Post by F6FLU »
OK Terry I will test BUT :
To be precise,
I'm not looking for why there are these errors (I know why: I modified the State file :-) )
I just want Log4OM not to modify any field during an import (an option? )
Dan - F6FLU
https://F6FLU.org
