Lag time after clicking spot
VE3CT
Post by VE3CT »
I am new to Log4OM. I have everything working. However, I cannot understand why it takes from 10 sec to over 20 sec after double clicking a cluster spot before Log4OM changes frequency and display. My PC is very fast running Win 10 Pro with a Ryzen 5 3600 CPU and 16 GB of high speed memory and CPU running on average less than 5%. With N1MM or Logger32 the same process is instantaneous.
What am I missing?
Thanks for any hints,
Art - VE3CT / W1AJT
Re: Lag time after clicking spot
Which version of Log4OM are you using? actual release number please - Not 'its the latest'
VE3CT
Post by VE3CT »
It's version 2.26.
Art
VE3CT
Post by VE3CT »
To refine the problem the issue is that the callsign populates immediately but the frequency display sometimes never changes although the rig changes frequency. Every indicator is green CAT, Winkey, cluster. I ma using Omnirig v2.1.
VE3CT wrote: 17 Feb 2023, 00:53 To refine the problem the issue is that the callsign populates immediately but the frequency display sometimes never changes although the rig changes frequency. Every indicator is green CAT, Winkey, cluster. I ma using Omnirig v2.1.
First please revert to the original Omnirig by Alex its version 1.2, the Swiss one has issues
Also update Log4OM to Beta 2.26.0.3
What radio do you use and what connection to your PC (USB, Interface to ACC or what)
VE3CT
Post by VE3CT »
Hello Terry,
I backed up my log and downloaded the beta version 2.26.0.3 along with Omnirig v1.2. Install no problem. All previous settings and log automatically migrated to beta version.
Lag time between double-click spot and transceiver (K3) frequency change plus L4 callsign box population average 3 seconds with an average of a total of 6 seconds to change the frequency display of L4.
Thanks for trying,
Art
Art
Email me so that I can get to the bottom of this
g4pop (AT) arrl.net
