IOCA - Islands Of Croatia Award
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the IOCA - Islands Of Croatia Award. Copy the attached xml file (it should be named award_IOCA.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
More information regarding the award can be found here: http://ioca.hamradio.hr/index.php/en/
Claus, EI7JZ/OE6CLD
award_IOCA.xml
(673.93 KiB) Downloaded 526 times
IOCA Award.jpg (29.28 KiB) Viewed 4998 times
Claus, OE6CLD/DJ0DX/EI7JZ
Re: IOCA - Islands Of Croatia Award
I wonder where you can find all those awards... :)
OE6CLD
Post by OE6CLD »
You can find the links for the awards in the post ;)
Just kidding. There are so many awards available, these would fill complete books. Many of the awards are based on working members of a club or organization or book numbers (like 10X, DIG, FOC, OMISS, WAB books, ...), this is nothing we can handle at the moment.
But we easily can support all the awards where you have to work certain entities or reference numbers, which are plenty :D
For an overview you can check e.g. http://www.dxawards.com/, which has information for many long and short term awards.
Claus
