GIOTA - Greek Islands On The Air
Moderator: OE6CLD
OE6CLD
Post by OE6CLD »
Hi all,
Please find attached the award definition for the GIOTA - Greek Islands On The Air award. Copy the attached xml file (it should be named award_GIOTA.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
More information regarding the award can be found here: http://www.greekiota.gr
Claus, EI7JZ/OE6CLD
award_GIOTA.xml
(234.81 KiB) Downloaded 597 times
GIOTA Award.jpg (39.61 KiB) Viewed 4573 times
Claus, OE6CLD/DJ0DX/EI7JZ
