A minor issue noted since v2.26, and introduction of new colors in confirmations.
One example; TF3VS is confirmed in LOTW, as you will see the light blue should be dark blue status.
Some logs report properly with correct color schema, others are a mix and match with no discernible pattern.
I resynced with LOTW the entire log, but no change.
I have read the manual, so think my interpretation is correct?
Gavin
ZL3GAV
COLOR SCHEMA
- ZL3GAV
- Advanced Class
COLOR SCHEMA
- TF3VS colours.png (49.8 KiB) Viewed 1039 times
- ZL3GAV
- Advanced Class
Re: COLOR SCHEMA
Since resolved with assistance via Nolan Ki5io. The solution is in the confirmations section choosing LOTW specifically.
Gavin
ZL3GAV
Gavin
ZL3GAV
