Signal meter display (option)
VK4IM
Post by VK4IM »
Hi
I wonder if Omnirig or the like allows for a signal "S" meter readings to be exported and displayed somewhere in the logger?
Not to populate the RST field, but rather allow the operator to view a signal reading while typing in information. (I don't touch type). I find sometimes when working a pile up, or concentrating on a weak signal, I have to take my eyes off the screen to give a report, often resulting in "I'll give your report on the next over".
Perhaps the "S" meter could go just above the start and end times as a simple bar graph.
Cheers
Adam VK4IM
CT1BXX
Re: Signal meter display (option)
Post by CT1BXX »
Hello Adam.
Your idea is quiet interesting, however you can have same result or evean better with FLRig.
With FLRig you could have a complete command with your transceiver.
Of curse It would be better to have all within Log4OM , but while we do not have it, I think FLRig is a very good tool for that purpose.
In case you want to see a bit more http://www.w1hkj.com/flrig-help/
73 Manuel Fernando CT1BXX
VK4IM
Post by VK4IM »
Thank you Manuel
I'll have a play after work today
Cheers
Adam VK4IM
VK4IM wrote: 16 Mar 2023, 06:12 Hi
Cheers
Adam VK4IM
Having checked several Omnirig rig ini files I have not found one that provides any S meter information so if its not available from Omnirig we cannot provide it
