With the new 2.27 version, real-time uploads are no longer carried out, although you can see the frequency and the connection is actually functional.
I had to go back to version 2.26.
HRDlog upload
Re: HRDlog upload
I answered you in the other thread.
But lets start from the beginning. What app do you want to connect? The incoming connection that you had before needs to be removed and re-added. This incoming connection can effect your upload as one of the parameters is specific to upload.
Whatever port your 3rd part app is on is what you need to use in log4om. We are not recommending ports.
Re: HRDlog upload
I'm current working with.
LOG4OM ver 2.26 + JTDX + JTalert
or:
LOG4OM ver 2.26 + WSJT-X
These two configurations works well and upload correctly the qso on hrdlog.
With the 2.27 the upload doesn't work
or:
Re: HRDlog upload
It's not working for me either. From version 2.27.1.2 (Win) upload to HRDLog does not work.
Re: HRDlog upload
Again, have you guys deleted the incoming connections and started from scratch?
It will NOT work unless you do this.
Re: HRDlog upload
It's not about incoming calls, it's about outgoing calls. It's an integration with HRDLog. Internally, everything works fine in Log4OM, but it does not export logged contacts to HRDLog, despite correctly configured data exchange parameters between services.
Re: HRDlog upload
AGAIN, Delete the incoming connections and re-add them!!!
The incoming connection controls the outgoing as there is a parameter in there for uploading QSOs to external services.
