Possible error (for me) in ADIF monitor
MI0JLC
Post by MI0JLC »
Hi Folks, Each time I log a new QSO via FT8/4 I get the following error
18:12:46.604 Info: [dje_zVYJ5HQAVFE5TZTHBEMFPJU7ALJAHHX64XQ_ejd] : [ADIF MONITOR] C:\Users\steph\AppData\Local\JTDX\wsjtx_log.ADI QSO not saved: EA8CPE|28/03/2023 18:12:00|17m|FT4. Skipped
Anyone know if this is normal, or if it is an setting error on my side.
I have included the full screen shot which seems to run as supposed to untill it gets to the ADIF_Monitor line.
Thanks, Steve, MI0JLC
18:12:40.088 Info: [dje_zYEFDG7SLXV6B5UVPTE78WRKFNQJGEPKLKW_ejd] : {51ccac6e-a1ea-4cd0-bce0-fc68c464688c} ADIF received from UDP service
18:12:40.088 Info: [dje_zYEFDG7SLXV6B5UVPTE78WRKFNQJGEPKLKW_ejd] : JTAlert<EOH> <CALL:6>EA8CPE<QSO_DATE:8>20230328<QSO_DATE_OFF:8>20230328<TIME_ON:6>181200<TIME_OFF:6>181237<FREQ:9>18.105406<FREQ_RX:9>18.105406<BAND:3>17m<BAND_RX:3>17m<MODE:4>MFSK<SUBMODE:3>FT4<DXCC:2>29<COUNTRY:14>Canary Islands<CQZ:2>33<ITUZ:2>36<CONT:2>AF<RST_SENT:3>+11<RST_RCVD:3>+05<LOTW_QSL_SENT:1>R<LOTW_QSL_RCVD:1>R<EQSL_QSL_SENT:1>R<EQSL_QSL_RCVD:1>R<GRIDSQUARE:6>IL18kc<DISTANCE:4>3071<TX_PWR:7>1007300<LAT:11>N028 06.250<LON:11>W017 07.500<COMMENT:25>FT4 Sent: +11 Rcvd: +05<NAME:9>José-juan<QTH:3>San<PFX:3>EA8<IOTA:6>AF-004<A_INDEX:1>3<K_INDEX:4>1.67<SFI:3>158<MY_GRIDSQUARE:6>IO64xm<MY_CQ_ZONE:1>0<MY_ITU_ZONE:1>0<OPERATOR:6>MI0JLC<STATION_CALLSIGN:6>MI0JLC<QSO_COMPLETE:1>Y <EOR>
18:12:40.104 Info: [dje_zPQSRHEAPNCVN6AJBQ5FZBHSUSMCQ_ejd] : Begin ADIF import
18:12:40.12 Info: * [dje_zGATHJAGKMRVYUZESM6ZL286RZ9UQ_ejd] [AWARDPARSER] : Award Management - Parse qso started on EA8CPE|28/03/2023 18:12:00|17m|FT4
18:12:40.726 Info: * [dje_zGATHJAGKMRVYUZESM6ZL286RZ9UQ_ejd] [AWARDPARSER - 605 ms] : Award Management - Parse qso terminated on EA8CPE|28/03/2023 18:12:00|17m|FT4
18:12:40.727 Info: * [dje_zPPF88X7ZEKNG74YYLDNGX_ejd] [AWARDPARSER] : Award Management - Parse log terminated
18:12:40.729 Info: * [dje_zPQSRHEAPNCVN6AJBQ5FZBHSUSMCQ_ejd][624 ms] : End of ADIF import
18:12:40.73 Info: [dje_zYEFDG7SLXV6B5UVPTE78WRKFNQJGEPKLKW_ejd] : {51ccac6e-a1ea-4cd0-bce0-fc68c464688c} received 1 QSO
18:12:40.731 Info: [dje_zVRT48CL8A2U23D37GUSF2_ejd] : ############### ADD QSO Callsign: EA8CPE Date: 28/03/2023 18:12:00 Band: 17m Mode: FT4
18:12:40.742 Info: [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] Search start on EA8CPE (originally EA8CPE)
18:12:40.745 Info: [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] EA8CPE FOUND IN CACHE!
18:12:40.746 Info: * [dje_zMHKFRAFDU5792C44FYSWD_ejd][3 ms] : [QRZCOM] Search finished on EA8CPE (originally EA8CPE)
18:12:40.757 Info: [dje_zVRT48CL8A2U23D37GUSF2_ejd] : QSO Callsign: EA8CPE Date: 28/03/2023 18:12:00 Band: 17m Mode: FT4 Saved
18:12:40.758 Info: [AdifManagement] : Begin export single QSO to ADIF string
18:12:40.758 Info: [AdifManagement] : Export QSO to ADIF file completed
18:12:41.157 Info: [dje_zYEFDG7SLXV6B5UVPTE78WRKFNQJGEPKLKW_ejd] : {51ccac6e-a1ea-4cd0-bce0-fc68c464688c} Process completed
18:12:45.78 Info: [dje_zPQSRHEAPNCVN6AJBQ5FZBHSUSMCQ_ejd] : Begin ADIF import
18:12:45.856 Info: * [dje_zGATHJAGKMRVYUZESM6ZL286RZ9UQ_ejd] [AWARDPARSER] : Award Management - Parse qso started on EA8CPE|28/03/2023 18:12:00|17m|FT4
18:12:46.585 Info: * [dje_zGATHJAGKMRVYUZESM6ZL286RZ9UQ_ejd] [AWARDPARSER - 729 ms] : Award Management - Parse qso terminated on EA8CPE|28/03/2023 18:12:00|17m|FT4
18:12:46.585 Info: * [dje_zPPF88X7ZEKNG74YYLDNGX_ejd] [AWARDPARSER - 5858 ms] : Award Management - Parse log terminated
18:12:46.594 Info: * [dje_zPQSRHEAPNCVN6AJBQ5FZBHSUSMCQ_ejd][813 ms] : End of ADIF import
18:12:46.594 Info: [dje_zVRT48CL8A2U23D37GUSF2_ejd] : ############### ADD QSO Callsign: EA8CPE Date: 28/03/2023 18:12:00 Band: 17m Mode: FT4
18:12:46.604 Info: [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] Search start on EA8CPE (originally EA8CPE)
18:12:46.604 Info: [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] EA8CPE FOUND IN CACHE!
18:12:46.604 Info: [dje_zMHKFRAFDU5792C44FYSWD_ejd] : [QRZCOM] Search finished on EA8CPE (originally EA8CPE)
18:12:46.604 Error: [DbSqlite][dje_z6NSAYHGMRM2QZXA_ejd] : [SQLITE] InsertUpdateDatabase Command error
[EXCEPTION] constraint failed
UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode
18:12:46.604 Error: [DbSqlite][SaveQso] : SQLITE SaveQSO exception while saving QSO with QsoId 20230328181245797
18:12:49.975 Info: [dje_zKXQRAHMWQXCG6SSN5C5P8ALTLF8A_ejd] : RemoteControl legacy message received
18:12:50.604 Info: [dje_zLM5KCTUPA4JMB4QDP6YHLJNG4NAQ_ejd] : [DELAYED SEND QSO ASYNC] Aligning QSO process started...
18:12:50.611 Info: [dje_zLM5KCTUPA4JMB4QDP6YHLJNG4NAQ_ejd] : [DELAYED SEND QSO ASYNC] Aligning QSO process completed
18:13:50.723 Info: [dje_zLM5KCTUPA4JMB4QDP6YHLJNG4NAQ_ejd] : [DELAYED SEND QSO ASYNC] Aligning QSO process started...
18:13:50.725 Info: [dje_zQH3JQ2NCULW2683ATPGG6VFRVWMGEUY5W2_ejd] : [EQSL UPLOAD] Uploading QSO on EQSL: EA8CPE|28/03/2023 18:12:00|17m|FT4
18:13:50.726 Info: [AdifManagement] : Begin export single QSO to ADIF string
18:13:50.726 Info: [AdifManagement] : Export QSO to ADIF file completed
18:13:51.29 Info: [dje_zADAZ275FYY6J5BNSX2AVQ_ejd] : [EQSL UPLOAD] Qso updated/added
18:13:51.29 Info: * [dje_zQH3JQ2NCULW2683ATPGG6VFRVWMGEUY5W2_ejd][564 ms] : [EQSL UPLOAD] ###### END ######
18:13:51.29 Info: [dje_z2H4WV9QTUU6P8K3GCN6F9RZF4XWA_ejd] : [QRZCOM UPLOAD] Uploading QSO on QRZ.COM: EA8CPE|28/03/2023 18:12:00|17m|FT4
18:13:51.29 Info: [AdifManagement] : Begin export single QSO to ADIF string
18:13:51.29 Info: [AdifManagement] : Export QSO to ADIF file completed
18:13:54.39 Info: [dje_z2H4WV9QTUU6P8K3GCN6F9RZF4XWA_ejd] : [QRZCOM UPLOAD] Upload successful: 'LOGID=901960103&COUNT=1&RESULT=OK' for QSO Callsign: EA8CPE Date: 28/03/2023 18:12:00 Band: 17m Mode: FT4
18:13:54.39 Info: [dje_z2H4WV9QTUU6P8K3GCN6F9RZF4XWA_ejd] : [QRZCOM UPLOAD] upload completed Callsign: EA8CPE Date: 28/03/2023 18:12:00 Band: 17m Mode: FT4
18:13:54.39 Info: * [dje_z2H4WV9QTUU6P8K3GCN6F9RZF4XWA_ejd][3100 ms] : [QRZCOM UPLOAD] ###### END ######
18:13:54.39 Info: [dje_z3CFYABV6WM92PPYN3HNDGHG3BNEGP45AWSE8C6EQ_ejd] : [UPLOAD CLUBLOG QSO] Uploading QSO on CLUBLOG: EA8CPE|28/03/2023 18:12:00|17m|FT4
18:13:54.405 Info: [AdifManagement] : Begin export single QSO to ADIF string
18:13:54.405 Info: [AdifManagement] : Export QSO to ADIF file completed
Re: Possible error (for me) in ADIF monitor
Stop using ADIF monitor and use the prescribed UDP method instead
MI0JLC
Post by MI0JLC »
So I take it the ADIF monitor is no longer needed with the prescribed UDP method up and running ?
No you use either/or
UDP provides greater functionality
MI0JLC
Post by MI0JLC »
Thanks for the info Terry. Will look into shutting on or the other down..
Make sure that your using the latest Beta version here https://www.log4om.com/l4ong/release/be ... 2_beta.zip
In any case you didn't missed anything, as the QSO was discarded due
"[EXCEPTION] constraint failed
UNIQUE constraint failed: Log.qsodate, Log.callsign, Log.band, Log.mode"
That means you already have the SAME QSO in the log
K0KO
Post by K0KO »
When importing my .adi file from LoTWQ, I am getting a similar error "ConstraintFailed Unique: log.updt, log.callsign, log.band, log.mode, callsign (for each contact)"
Log Saved
Save Complete.
When I check many of the call signs, they do not show as being confirmed.
What am I doing wrong?
Tnx,
Bill - K0KO
