My Yaesu FT-DX10 is connected via CAT. Tuning the radio changes the frequency/band in Log4OM. However, when using the cluster, if I click on a spot, it loads the call sign information but does not change to that frequency.
Is it supposed to change the frequency? If yes, is there a setting to enable/disable it?
Double click is the same as single click - it populates the call sign information but no change in frequency.
The frequency does change when using the band map tool.
The radio is connected via Omni-Rig and running portable Version 2.26.0.3 BETA
Selecting Entry in Cluster Does Not Change Frequency
Re: Selecting Entry in Cluster Does Not Change Frequency
First your welcome. Out of date please install latest Beta release
Change omnirig polling rate to 100
Single click = lookup
Double click = lookup and QSY
Terry,
Are these settings in OmniRig?
The polling rate is set to 100ms.
- Single click = lookup
No I was just describing how Log4OM cluster works as detailed in the user guideW4RXK wrote: 07 Apr 2023, 14:50 Terry,
Are these settings in OmniRig?I do not see settings like this.
