It seems awards definitions are located at <user>\AppData\Roaming\LogOM\awards.
I use Log4OM on two computer and I have shared log database via DropBox so I can have it synchronized. I need awards definitions to be synchronized too. Can we have option to set location for award files or at least to use the same location where log database is?
Path to awards definitions directory
Re: Path to awards definitions directory
In the next version the awards definitions will be automatically updated from our central server so if you select auto update on both computers you will have what you require
