Hi all... just recently, when I double click on an entry in the 'Recent QSOs' list, or select one, right click and select 'Edit QSO' nothing happens. It looks like the Edit QSO window is not opening correctly.
This is on version 2.27.1.0. It worked before -- not sure why it's stopped now.
Any ideas?
thanks
Don VE7ATJ
Edit QSO window not working?
Re: Edit QSO window not working?
Found it... it's apparently a 'Windows' problem where sometimes the screen gets 'lost' or displays off-screen. (Especially prevalent when switching displays with different resolutions.)
Solution is to go to Windows Task Manager, find Log4OM, then click on the caret (arrow) beside it, to drop down both sub-tasks (the Edit QSO window and the main screen). Then, right click on the Edit QSO task and select Maximize and that should bring it back on screen. Once you reposition the window where you want it on your display, it should come up there from every time hence.
Don VE7ATJ
Don VE7ATJ
