Log4OM2 Flirg Hamlib stopped working
M0LZN
Post by M0LZN »
Had Log4om, flirg and hamlib working ok. I followed this information here
Its now stopped working :(
Flirg and WSJT-X works great its just Log4OM not working.
I tried running C:\Users\james\AppData\Roaming\Log4OM2\hamlib\rigctl.exe from the command line with the command rigctl.exe --model=4 -z and it connects OK.
When i try to start CAT in log4om i get the following in the log.
Code: Select all
2023-05-09 10:25:23.6555 INFO:        [ProgramStorage] : [CAT STATUS CHANGED] Running: True
2023-05-09 10:25:23.6895 INFO:        [dje_zBL9AH3CU_ejd] : [HAMLIB] DAEMON STARTED: C:\Users\james\AppData\Roaming\Log4OM2\hamlib\rigctld.exe --model=4 -z
2023-05-09 10:25:23.7991 INFO:        [dje_zBL9AH3CU_ejd] : [HAMLIB] Hamlib Process exit code: 1
2023-05-09 10:25:23.8001 INFO:        [dje_zBL9AH3CU_ejd] : [HAMLIB] DAEMON STOPPED. Hamlib instance terminated
2023-05-09 10:25:26.7097 ERROR:       [HamlibEngine][dje_zVLJWE8AQKNFMGJXYWVR3X5B6AJ8A_ejd] : [EXCEPTION] No connection could be made because the target machine actively refused it 127.0.0.1:4532 System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 127.0.0.1:4532
   at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
   at L4ONG.BL.CAT.HamlibEngine.dje_zVLJWE8AQKNFMGJXYWVR3X5B6AJ8A_ejd()
2023-05-09 10:25:26.7097 INFO:        [HamlibEngine] : [HAMLIB] Stop polling. Timeout True
2023-05-09 10:25:26.7107 INFO:        [ProgramStorage] : [CAT STATUS CHANGED] Running: False
My system is
  • Windows OS - W11
  • Processor - Processor Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz, 2901 Mhz, 4 Core(s), 8 Logical Processor(s)
  • Ram type - 32Gb - 2 x 6GB - 2Rx8 DDR4 SODIMM 2666MHz
  • Log4OM release number 2.27.1.0
  • Release numbers of associated software flrig 1.4.8, wsjt-x 2.6.1
  • Radio make and model Icom 7300
  • CAT Interface - flrig
  • Cat control type Hamlib
Any help would be gratefully appreciated
M0LZN
Re: Log4OM2 Flirg Hamlib stopped working
Post by M0LZN »
Been digging more in to this.
From the CMD at C:\Users\james\AppData\Roaming\Log4OM2\hamlib.
Model 4 is flrig
rigctl --model=4 -Z work and I can query the radio via hamlib
Now from the quick log view Log4OM uses rigctld and if i try rigctld --model=4 -Z from the command line it does not work.
rigctl - control radio transceivers and receivers https://hamlib.sourceforge.net/html/rigctl.1.html
rigctld - TCP radio control daemon https://hamlib.sourceforge.net/html/rigctld.1.html
So even though I have it set as serial connection in Log4OM it looks like its trying to use network connected .
Not sure if this helps or I'm going down the wrong path.
Any ideas?
James,
I gave Lele a head's up to look into this.
M0LZN
Post by M0LZN »
KI5IO wrote: 31 May 2023, 16:34 James,
Cheers, latest version v2.28.0.0 seems to have fixed it :)
M0LZN wrote: 07 Jun 2023, 18:20
James,
Tnx for follow-through and update.
