MSHV Configuration
Ic8fax
MSHV Configuration
Post by Ic8fax »
GN, I need someone help me to configure MSHV and Pstrotator with log4om2, tnx ic8fax
Re: MSHV Configuration
Ic8fax wrote: 15 May 2023, 20:12 GN, I need someone help me to configure MSHV and Pstrotator with log4om2, tnx ic8fax
Jacob,
As best I can determine PST Rotator setup is pretty self-explanatory. Settings / Configuration / Antenna Rotator ...
Pls d/l and review the extensive User Guide dated: 23/03/2023 9:15PM
You can search the PDF, but to give you a boost check on Page 175 for PST Rotator.
As for MSHV you can start looking on Page 216 of the User Guide.
Ic8fax
Post by Ic8fax »
Tnx Nolan, i will try ,I tried that procedure but it didn't work, maybe I did something wrong, I'll try again
