Log4om V2 CAT control of Flexradio
I am running into a issue getting Log4OM to work with the FlexRadio for CAT. I have tried doing TCP CAT direct to the FlexRadio and through Slicemaster. Is an updated guide available? The current guide does not match the Log4omV2 interface and options. CAT say its connected, but don't get any information from the FlexRadio into Log4om. Any help on what setting you are using. Setting this up with the latest version of FlexRadio SDR 3.4.23 available at this time.
Re: Log4om V2 CAT control of Flexradio
I used smartcat when I had a flex and Log4OM worked fine with that for cat control plus the Flex Winkeyer worked with Log4OM keyer
I eventually disposed of the Flex after several issues and purchased a SunSDR 2 DX Pro so I dont have a Flex to test with anymore.
