Feedback on 2.27.1.0 - no automatic log upload
dk2hs
Post by dk2hs »
I recently upgraded to 2.27.1.0 (portable version) and I have discovered that no automatic upload of th elog to qrz.com etc had happened. I went back to 2.26.0.0 and all is fine again, the automatic upload is working fine
Re: Feedback on 2.27.1.0 - no automatic log upload
dk2hs wrote: 30 May 2023, 07:52 I recently upgraded to 2.27.1.0 (portable version) and I have discovered that no automatic upload of th elog to qrz.com etc had happened. I went back to 2.26.0.0 and all is fine again, the automatic upload is working fine
OM,
You must have skipped over the Release Notes and many other posts in the Forum regarding the "required" UDP changes with that release.
Here is a link to one advisory: https://forum.log4om.com/viewtopic.php?p=43147#p43147
I strongly suggest you also d/l and install V 2.27.1.10 - https://www.log4om.com/download/
Lele has also posted this advisory on working with JT modes.
https://www.log4om.com/l4ong/usermanual ... ith_JT.pdf
Also there is detailed information in the most current User Guide starting on Page 216. You can download the "current" User Guide at: Help / User Guide / English (force update) ... After a short span of time the d/l will complete and the U.G. will open in your preferred PDF viewer.
