Feedback on 2.27.1.0 - no automatic log upload
Posted: 30 May 2023, 07:52
by dk2hs
I recently upgraded to 2.27.1.0 (portable version) and I have discovered that no automatic upload of th elog to qrz.com etc had happened. I went back to 2.26.0.0 and all is fine again, the automatic upload is working fine
Re: Feedback on 2.27.1.0 - no automatic log upload
Posted: 30 May 2023, 10:04
by KI5IO
dk2hs wrote: 30 May 2023, 07:52
OM,
You must have skipped over the Release Notes and many other posts in the Forum regarding the "required" UDP changes with that release.
Here is a link to one advisory:
https://forum.log4om.com/viewtopic.php?p=43147#p43147
I strongly suggest you also d/l and install V 2.27.1.10 -
https://www.log4om.com/download/
Lele has also posted this advisory on working with JT modes.
https://www.log4om.com/l4ong/usermanual ... ith_JT.pdf
Also there is detailed information in the most current User Guide starting on Page 216. You can download the "current" User Guide at:
Help / User Guide / English (force update) ... After a short span of time the d/l will complete and the U.G. will open in your preferred PDF viewer.
