WUST Certificate
Moderator: OE6CLD
OE6CLD
WUST Certificate
Post by OE6CLD »
Hi all,
Please find attached the award definition for the WUST - Worked US Territories Award. Copy the attached xml file (it should be named award_WUST.xml) into the <user>/AppData/Roaming/LogOM/awards folder and restart Log4OM.
More information regarding the award can be found here: http://www.metrodxclub.com/wust_award.htm
Claus, EI7JZ/OE6CLD
award_WUST.xml
(11.14 KiB) Downloaded 615 times
Claus, OE6CLD/DJ0DX/EI7JZ
