install of 2.28.0.0 success except
ve3wej
Post by ve3wej »
Now I have the signal report boxes blinking, can I stop it from doing that. I even tried entering a call as if I worked someone, then it would not let me enter a report because it was blinking
yes I did look at the manual. Is it updated each release?
Dave ve3wej / ve3ie
Re: install of 2.28.0.0 success except
ve3wej wrote: 07 Jun 2023, 21:14 Now I have the signal report boxes blinking, can I stop it from doing that. I even tried entering a call as if I worked someone, then it would not let me enter a report because it was blinking
Dave,
Terry updates the U.G. at any given time when there is a need. I have recommend to users for years to check for U.G. update at least twice a month. Easily done at: Help / User Guide / English (force update) ... click on that and after a few moments the most recent U.G. will open in your preferred PDF viewer. I recommend that you then save a copy to your local PC.
The current U.G. was just updated on June 05, 2023 at 3:55PM
As for your first question - Are you referring to the RST Sent & Received boxes?
You did not provide any additional information so I will suggest you do the below to get back to basics:
Have Log4OM running by "itself". Do NOT also have any other APPs running and connected to Log4OM. IE: WSJTx, JTDX, JTAlert, Gridtracker, etc..
Only have the CAT connected to your rig and that is not necessarily needed either.
Bottom line ... have Log4OM running by "itself" and then see if the issue you noted persists.
Also ... have you modified the rst.xml file via the Resources Editor?
A bit more clarification is needed please.
ve3wej
Post by ve3wej »
I am not sure what was making the rst boxes blink, but have stopped, and all I did was restart today.. will watch for it to occur again, and post images, if I can
Dave ve3wej / ve3ie
ve3wej
Post by ve3wej »
oh, and user guide has now been updated, thanks for that
Dave ve3wej / ve3ie
ve3wej
Re: install of 2.28.0.0 success except follow up
Post by ve3wej »
I now have it blinking again. running wsjtx ( improved) and blinks when I change to ft4 mode
Recording 2023-06-08 184356.mp4
(38.49 KiB) Downloaded 337 times
Dave ve3wej / ve3ie
What radio do you have selected in WSJT 'Radio' menu
ve3wej
Post by ve3wej »
wsjtx has my ft-dx10, via win4yaesu virtual com port
Dave ve3wej / ve3ie
ZL3GAV
Post by ZL3GAV »
I have encountered the blinking RX/TX boxes as well, using FTDX10, JTAlert, and JTDX. It locks Log4OM up and is unusable.
This is intermiitent, and I have yet to etablish a pattern.
Gavin
ZL3GAV
ZL3GAV wrote: 10 Jun 2023, 05:35 I have encountered the blinking RX/TX boxes as well, using FTDX10, JTAlert, and JTDX. It locks Log4OM up and is unusable.
Gavin
ZL3GAV
Gavin,
Are you using V 2.28.0.0 as well?
What CAT control?
Are you also using a Win4(radio) suite?
Next time it happens check your log to see if it captures any errors. You could also change the log level to Debug and that will provide more granular data that might help provide a clue as well.
Probably a VSP issue
