KH8RRC gives us Country = Hawaii instead of American Samoa
Can you tell me what to change and where for Log4OM to display the correct country (American Samoa)
THANKS
Bad Country
Bad Country
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: Bad Country
If your using QRZ that is where the country is derived from and upon checking that call QRZ lists it as below
KH8RRC Hawaii flag Hawaii
C/O DAVID A FLACK
"RRC" TUTUILA IOTA CLUB
PO BOX 29761
HONOLULU, HI 96820-2161
USA
Using Hamcall provides American Samoa
With Info providers dissabled using Log4OM internal country file, cty file and Clublog exceptions also returns American Samoa
Sometimes QRZ dont return the latest dxpedition or contest data but thats usually due to the station not updating their QRZ information.
C/O DAVID A FLACK
PO BOX 29761
USA
Re: Bad Country
same here
it means that I have to modify the CTY file?
Dan - F6FLU
https://F6FLU.org
https://F6FLU.org
Re: Bad Country
No, that means you have to switch off qrz.com to get the data from cty. Or you may change to hamcall.
By the way, HamQTH gives also American Samoa as country so also a lookup change to that provider is helpful.
