LOTW CFM report
ei6kw
LOTW CFM report
Post by ei6kw »
Hi all,
Is there an detailed report after LOTW confirmations import available?
Thanks,
__
73!
de EI6KW, Slav
[url]https://www.hamqth.com/ei6kw[/url]
Re: LOTW CFM report
Detailed report showing exactly what information and down to what level (Individual QSO's or by entity, band and mode?
Report in what format, by an export to CSV or display on the PC?
ei6kw
Re: LOTW CFM report
Post by ei6kw »
G4POP wrote: 10 Jul 2023, 09:58 Detailed report showing exactly what information and down to what level (Individual QSO's or by entity, band and mode?
I mean any simple report e.g. txt file showing all imported QSO records from LOTW in last import with info whats happened in log e.g. OK, QSO not found in log etc. etc.
Reason I am asking for this is that very often in download confirmations window I can see:
ADIF FULL document parsed: 1 qso found.
SEARCHING FOR NEW AWARDS...
SAVING FULL QSO's...
SAVE COMPLETE
LOTW UPDATING STATISTICS...
LOTW END
One QSO was found but I how I can to know which one? No call sign or other info abt this QSO.
Today's morning 35 QSO's was found but only one call sign was showed in download confirmations window. Whats abt other 34 QSOs?
__
73!
de EI6KW, Slav
Re: LOTW CFM report
OK
Two reports are already possible for 'Incoming' LOTW files but to see the details it is first neccessary to go to Help/Log Level and select 'Trace' instead of 'Info'
If you want to permenantly have the program in 'Trace' mode you can set that in the Program Config/program settings menu 'Default Log Level' BUT BE WARNED! DOING THAT WILL SLOW YOUR PC DOWN DRAMATICALLY!
Now when you download from LOTW you will see more detail in the download window and this can be saved by clicking 'Save log' at the bottomof the download window.
In addition the 'Incoming' ADIF file is saved to the LOTW folder in your config (Help/Open config folder) and the file is named something like "20230710112659_LOTW_INCOMING_FILE.ADI"
The ADIF file displays the information shown below:
ARRL Logbook of the World Status Report
Generated at 2023-07-10 11:26:59
for g4pop
Query:
QSL ONLY: YES
QSL RX SINCE: 2023-06-01 00:00:00 (user supplied value)
<PROGRAMID:4>LoTW
<APP_LoTW_LASTQSL:19>2023-07-04 12:40:03
<APP_LoTW_NUMREC:1>5
<eoh>
<APP_LoTW_OWNCALL:5>G4POP
<STATION_CALLSIGN:5>G4POP
<CALL:5>GB4LD
<BAND:3>40M
<FREQ:7>7.10500
<MODE:3>SSB
<APP_LoTW_MODEGROUP:5>PHONE
<QSO_DATE:8>20230625
<APP_LoTW_RXQSO:19>2023-06-25 11:44:07 // QSO record inserted/modified at LoTW
<TIME_ON:6>111804
<APP_LoTW_QSO_TIMESTAMP:20>2023-06-25T11:18:04Z // QSO Date & Time; ISO-8601
<QSL_RCVD:1>Y
<QSLRDATE:8>20230704
<APP_LoTW_RXQSL:19>2023-07-04 12:40:03 // QSL record matched/modified at LoTW
<DXCC:3>223
<COUNTRY:7>ENGLAND
<APP_LoTW_DXCC_ENTITY_STATUS:7>Current
<PFX:3>GB4
<APP_LoTW_2xQSL:1>Y
<GRIDSQUARE:4>IN79
<CQZ:2>14
<ITUZ:2>27
<eor>
