Change in My Station from short to long path distance im log is not changing
DF2MC
Post by DF2MC »
With a saved QSO, change in My station Antenna path from short path to long path, the distance in the log does not change, is that correct ??
73 Hans DF2MC
Re: Change in My Station from short to long path distance im log is not changing
Hello Hans,
i tried this too with changing to LP and changing the antenna direction but same result. So it looks like
that Log4OM is calculating the distance only between the Grids without using the path. So at the moment
it looks like that it´s correct.
Calculating from the Grids & the Path should be a "Feature Suggestion" ....
DF2MC
Post by DF2MC »
Thanks Jürgen,
In the morning there are some LP connections to Japan and I wanted to change the path to see the LP distance, a pity not possible.
OK, I am using Simon's World Map to check the LP distance, super programm !
By the way, I am using Log4OM2_2_28_0_0, sorry to mentioned it.
vy 73 Hans DF2MC
