comments field
kn4tc
comments field
Post by kn4tc »
I noticed that the comments field has a blank drop down list. Is there any way to store comments here that can be easily retrieved to fill the field without retyping them?
Re: comments field
kn4tc wrote: 06 Aug 2023, 18:09 I noticed that the comments field has a blank drop down list. Is there any way to store comments here that can be easily retrieved to fill the field without retyping them?
Joel,
If you click on an active spot in the cluster and then tap the drop down list it will have some values there. The values are being picked up from the "Note" field that is part of the cluster feed.
If those default values don't fit then you can key in what you wish before you save the QSO.
As for have a "pre-saved" list to then pick/choose from .... No, that does not exist.
kn4tc
Re: comments field
Post by kn4tc »
Thank you
