Single fied update for QSL info
KE4BCN
Post by KE4BCN »
Is there a way to update a single QSL field such as QRZ sent, Clublog sent as an example. Somewhere along the way when I changed logging programs these fields did not populate correctly. Checking the QRZ and Clublog websites they show that the QSO's have already been uploaded. Or is it possible to add these to the single field update in QSO Manager.? Thanks
Re: Single fied update for QSL info
KE4BCN wrote: 16 Aug 2023, 17:30 Is there a way to update a single QSL field such as QRZ sent, Clublog sent as an example. Somewhere along the way when I changed logging programs these fields did not populate correctly. Checking the QRZ and Clublog websites they show that the QSO's have already been uploaded. Or is it possible to add these to the single field update in QSO Manager.? Thanks
Ross,
You can modify Sent/Rcvd fields in the QSL Manager routine.
KE4BCN
Post by KE4BCN »
Thank you worked perfectly.
