Cluster Screen (F8)
K8TJM
Cluster Screen (F8)
Post by K8TJM »
Hello All,
Win 10. Yaesu FT-950. Log4OM V. 2.28.0.4 Beta. WSJT-X V. 2.6.1
When I'm in the cluster window (F8) (filter set to digital) and double click on the date column to pick that contact it puts the rig into USB RTTY. If I'm on 14.074 and using FT8 and I click on a FT4 contact from the cluster screen the rig (and WSJT-X) will switch to 14.080 however it will stay in the FT8 mode and I need to manually click on FT4 in WSJT-X to be able to start to decode. Same goes for going from FT4 to FT8 via the cluster screen. The same behavior takes place if I click in the band map.
The FT-950 has SSB (USB LSB), FM, AM, CW LSB, CW USB, RTTY USB, RTTY LSB, PKT USB and PKT LSB. Putting the rig into RTTY mode changes some of the filters and puts the rig into full power mode (or what ever the setting is via menu item 111TGEN). In USB or LSB mode I am able to go through the US Navigator interface and use the RF out pot for output power.
Thanks!
Terry / K8TJM
