I'm using the following software...
Log4OM version 2.28.0.0
JTDX version 2.2.159 improved
JTAlert 2.60.9
Logging is done by JTAlert and is working fine but for some reason FT8 QSO's are not being sent to Clublog automatically from Log4OM.
If I have a voice QSO and enter the QSO to Log4OM the QSO is sent to Clublog without any issues.
Any ideas on how to solve this or do I have to manually upload to Clublog?
Andy
FT8 QSO's not sent to Clublog
Re: FT8 QSO's not sent to Clublog
Please read info on replacing the UDP connection for uploads
There are a number of post on this forum about it and messages from lele and me
User guide also is updated to reflect changes made
The release notes informed users at the time we changed
OK, thanks, been away from radio for a while as I emigrated, now licenced as F4VWD. Seems the whole UDP thing changed in the interim...
Andy,EI8KF wrote: 01 Sep 2023, 17:29 OK, thanks, been away from radio for a while as I emigrated, now licenced as F4VWD. Seems the whole UDP thing changed in the interim...
Noted you have moved. Would you like for me to change your Log4OM Forum login from ei8ke to f4vwd?
Password will not change. Just advise and I'll process ASAP.
V.2.32.1.0 does not mark sent in
clublog frame, I remember hamqth
it was the same...
I advise you not to download the latest version,
use the old ones if you have to..
it was the same...
Andy
I’m curious, what radio do you use when you have this problem?
Clublog does not count for any awards as far as I know, thats is why its not in the list of confirmation filters in the clusterSP1JQJ wrote: 29 Apr 2024, 06:46 V.2.32.1.0 does not mark sent in
it was the same...![]()
use the old ones if you have to..![]()
