it's not turning on the right frequency
SV4QNP
Post by SV4QNP »
Good morning from SV4QNP. I have a problem here for a while. I have the ft dx 3000 and I saw that when I go to turn the transceiver from the program by double-clicking again on the station that does cq several times it turns to the station but it is not on the right frequency, i.e. it could be + 1400 or -1400. that is, if someone broadcasts at 14200 and I see them in the cluster, they will not connect me there, but they can click to take me to 14201.400. when I press again for a second time, it turns normally at the correct frequency
Re: it's not turning on the right frequency
Which Windows Version ? Which Log4OM Version (e.g. 2.28.0.8) and what are you using for the CAT connection ? Hamlib or Omnirig ?
Without these Informations it´s nearly impossible to give a support.
SV4QNP
Post by SV4QNP »
Windows 10 and omnirig . Log4om 29 last version the cable is usb to rs 232
SV4QNP
Post by SV4QNP »
DF5WW wrote: 15 Sep 2023, 04:53 Which Windows Version ? Which Log4OM Version (e.g. 2.28.0.8) and what are you using for the CAT connection ? Hamlib or Omnirig ?
