Yesterday i´ve checked an ADIF from a friend in Sweden. In 2011 he has logged all contacts 3 times ...... I made a new database in L4O and imported his Log. After importing al Doubles with exact the same Time, Band Mode are gone but there was another 700 QSO with a little difference in the time (+ 10 to + 50 seconds) ....
Would be nice if it´s possible to have a timeset for eleminating doublets/tripples while importing an ADIF, i think so +/- 2 minutes if all other data (Date, Band, Mode, Call) are identical.
Or do we have a funktion like this i´ve never found
DF5WW wrote:Yesterday i´ve checked an ADIF from a friend in Sweden. In 2011 he has logged all contacts 3 times ...... I made a new database in L4O and imported his Log. After importing al Doubles with exact the same Time, Band Mode are gone but there was another 700 QSO with a little difference in the time (+ 10 to + 50 seconds) ....
The problem Juergen is that we have to have a time margin otherwise things like LOTW imports won't work because they allow a +\- of 30 minutes for matching
i think a LotW with +/- 30 minutes isn´t a problem. I have had QSO´s in the SA2BRN Log like 7:00:00 UTC, 7:00:00 UTC and 7:00:54 (all 3 with same call, band, date and mode) ..... one of the 7:00:00 will be deletet while importing to L4O but not the tripple with 7:00:54 ..... It was a hard work to delete around 700 QSO manually
Or is there a simple way with a 3rd party software to delete doublets and tripples from an existing ADIF ??? That would help for the next time i check a log from another OM for doublets
Maybe Log4OM could, while importing to detect possible duplicates and offer user to decide if he wants to keep them or not. That way he still has to remove them manually, and thus decide if they should be kept or are real duplicates, but at least process would be fast and easy.
Tried ADIF Master but it hasn´t a duplicate removing facility
I´ve tried open and import. If i use "Import" the software told me "This file is ADIF formattet. Please open this file directly" ..... In Import Option i have only Cabrillo, CT Files, TRlog Files or "all log files" ..... But the software don´t import the ADIF
DF5WW wrote:I´ve tried open and import. If i use "Import" the software told me "This file is ADIF formattet. Please open this file directly" ..... In Import Option i have only Cabrillo, CT Files, TRlog Files or "all log files" ..... But the software don´t import the ADIF
Yes it does
Check that the ADIF file extension is .adi (not .adif) if its .adif change it to .adi and it will open fine - see image below of an ADIF file that I opened in ADIFMaster
Screenshot 2014-06-10 15.26.10.png (114.16 KiB) Viewed 7462 times
