Page 1 of 2
Configuring QSO View Screen (F7)
Posted: 02 Oct 2023, 21:45
by G8LIY
Configuring the QSO View(F7) Screen with "Grid Configuration"
I'm missing an element to add on the view...
I have added [X] , Removed [ ] and renamed various elements.
But there "is" no option for [X] Club Log Received, there "is" a [X] Club Log Sent option. (remaned to "CLUB-S")
Any advice..??
Thank... Dave ~ G8LIY
- QSO-F7-CONFIG.PNG (23.21 KiB) Viewed 1954 times
Re: Configuring QSO View Screen (F7)
Posted: 26 Oct 2023, 01:12
by G8LIY
Can anyone help with the missing field..??
Many Thanks
Dave ~ G8LIY
Posted: 26 Oct 2023, 02:04
by KI5IO
Dave,
Clublog does not provide a QSL download option.
Posted: 26 Oct 2023, 02:48
by G8LIY
KI5IO wrote: 26 Oct 2023, 02:04
Dave,
I'm not asking for LOG4OM to Automatically Download directly from Clublog
I want to import the adif file that is downloaded from Clublog to get the Confirmations
I understand Downloads from Clublog are manual, there is a button to do it.
Posted: 26 Oct 2023, 12:04
by KI5IO
Dave,
You should be able to d/l the ADIF from Clublog and then import that ADIF into Log4OM without any issues.
As for the Sent/Received columns ... I use the columns that are adjacent to the Sent Date / Received Date. Those columns appear in all the external sources no matter the source I choose. IE: LOTW, Clublog, QSL, etc..
I've relabeled the columns as well.
Note image below that shows the two columns I use for my installation.
Ergo ... for whatever reason I don't use the columns in my grid that are already labeled for the source.
You could add those columns and label as you need and see what it presents you. I think it will work FB, but give it a test and see.
I've added the LOTW specific columns for a test and it appears they show the same data as the general ones I've been using for many years. See image below for my test.
Posted: 26 Oct 2023, 12:51
by G8LIY
KI5IO wrote: 26 Oct 2023, 12:04
Dave,
Hi Dave,
Exactly...
Yes, I can download the adif file from Clublog
Yes, I can import the adif file into LOG4OM
"But"
The Clublog "R" Tick Box [ ] is "Missing/Not Present" in the Grid Configuration Choices..??
(The Clublog "S" is present, per my original post)
73 Dave
Posted: 26 Oct 2023, 14:17
by KI5IO
Dave,
I understand what you have said, but you have not taken the step to use/test the other two columns I noted in my post w/images above.
There is not a Clublog - R as they don't provide a download.
In light of what you are trying to do ... try the work-a-round that I noted above and see if that will suffice for your needs.
If that works (I'm sure it will) then you will be good to go.
But ... note that my work-a-round is applicable to the grid views in the QSL Manager panel.
You are wanting all this data viewable on the Recent QSO (F7) tab (as noted in your first post).
That being said I suggest the below:
You can also formulate a Feature Request and post in that section of the Forum.
Posted: 26 Oct 2023, 16:25
Dave
All confirmation type field are in QSL manager not the same list in recent QSO'S
Posted: 27 Oct 2023, 00:21
by G8LIY
KI5IO wrote: 26 Oct 2023, 14:17
Dave,
Hi
per my screenshot I already have LoTW S & R and eQSL S & R and QRZ S & R and Clublog S,,, Clublog "R" is simply missing.
Clublog provide the data QSL_RCVD = "Y" when there are QSO matches,
It is in the ADIF, download Settings > Callsign
Posted: 27 Oct 2023, 00:24
by G8LIY
G4POP wrote: 26 Oct 2023, 16:25
Dave
Hi Terry
Thanks,
So all other confirmations S & R are available on the grid,
The only one missing is Clublog "R"
Will it be added.?
Regards ~ Dave
