Hi All
Using Version 2.26.0.7 It is taking a long time for the splash screen to close when shutting the program,
This has just started to happen since I upgraded TQSL,
The QSO are uploaded to LoTW with no issue, just when I close the program and then close the LoTW pop up screen, the Log4OM splash screen says,
Aschrionious (spelling) activies and a countdown timer 60,50,40 ect
Any ideas, and I know that there is a newer version, but I don't fancy having to receate all my UDP's
Trevor
EI2GLB
I'll try to get a screen shot next time it happens,
Slow to Close
Re: Slow to Close
Trevor
You really need to update and renewing UDP is no issue as long as you note the original settings before you do
Re: Slow to Close
Hi Terry
So I bit the bullet and went for it, so far it all seems to be ok,
One question,
UDP Proxy in connections,
I had one setup in this on my old config and I didn't take all the info so I can not recreate it,
What is this used for?? I had a look at the manual but I still am not sure,
Trevor
EI2GLB
One question,
Trevor
EI2GLB
Re: Slow to Close
No you can ignore the proxy setting tabEI2GLB wrote: 18 Oct 2023, 11:50 Hi Terry
One question,
Trevor
EI2GLB
Re: Slow to Close
Thanks Terry,
Trevor
EI2GLB
Trevor
EI2GLB
