QSO End Time
k5gs
QSO End Time
Post by k5gs »
Is there a configuration setting that will log the QSO End Time instead of the QSO Start Time?
The way I operate is to enter the call sign to get a beam heading, but that also sets the Start Time. I typically click on Worked Before (or something else) and the QSO Start Time gets locked while the End Time increments.
I may not work the station for 20 - 30 minutes or more.
While LoTW has a +/- 30 minute window, unless something change ClubLog's window is 15 min +/-.
Sometimes I forget to fix the time :cry:
Cheers,
GS K5GS
EI2GLB
Re: QSO End Time
Post by EI2GLB »
Hi Gene
Not sure if this is a perment fix but if you unclick lock start time it will match the end time,
Trevor
EI2GLB
Screenshot 2023-10-23 152703.png (4.7 KiB) Viewed 811 times
k5gs
Re: QSO End Time
Post by k5gs »
Hi Trevor,
Thanks, did what I want.
Now I have to remember to unlock before logging the Q.
Thanks,
GS
