Wrong DXCC
9k2hn
Wrong DXCC
Post by 9k2hn »
I'm using LOG4OM v 2.29.0.2 when I log YJ0TT I get the country name as USA, it seems log4om pulling the information from qrz.com. How can I force it to use CTY file?
Re: Wrong DXCC
Assuming you have the clublog and cty check boxes checked in Program Confiy/info providers/configuration you could try using HamQTH or Hamcall instead of QRZ.
Alternatively get QRZ or the call owner to fix it their end, otherwise change it manually which is probably quicker!
9k2hn
Re: Wrong DXCC
Post by 9k2hn »
My question was how to force it to use cty file instead of qrz.com?
Re: Wrong DXCC
Have you done "RTFM" (Read the - Edited by G4POP - manual) and have you checked your Settings here ???
9k2hn
Re: Wrong DXCC
Post by 9k2hn »
Thank you for the reply. Have you tested it with the example I gave in my first post? I have done what you told me and still, it is pulling the info from qrz.com. YJ0TT is still showing as USA due to a user error in qrz.com
If it can not be done it is fine, But I would be happy if it could be done the way I described
Re: Wrong DXCC
Until recently it was the way you request but we had to fix the setings because it was confusing too many users so follow my earlier comments, repeated below
9k2hn
Re: Wrong DXCC
Post by 9k2hn »
Thank you Terry it is clear now.
