I have had the problem for a couple of days. Last night before I went to bed I installed the most recent Beta Version of LOG4OM-2. I was using the Cluster W3LPL to get spots I was sending the spots via #23 UDP, and having FRStack pick up the spots to SmartSDR. But when I got up this morning I checked and saw that LOG4OM-2 was frozen. I had to perform a CTRL ALT DELETE and stop the program. And I have been having this issue for the past 3 days. It seems that LOG4OM Bombs for some unknown reason. I am not getting any error messages though. This does not occur when I use N1MM Plus It just seems to be with LOG4OM-2. It seems as though you can start LOG4OM-2, but you can't keep the program running after a period of time. One thing I have not tried is to bring up the program and not have it send spots to SmartSDR. I just wonder if that might be the reason that the program is bombing? I like LOG4OM-2 and the features that it has. Yet, to have to Control Alt Delete after a period of time because the program freezes, just doesn't seem right. Does anyone have any suggestions? I guess if worse comes to worse, I could go back to N3FJP or use another logger that works well with Flexradio.
Mark Griffin, KB3Z
LOG4OM-2 Freezes with my Flexradio 6400M
Re: LOG4OM-2 Freezes with my Flexradio 6400M
Check the log file it will probably define the error (Its in the Help menu)
